AV32R connection to Subwoofer
Discussion in 'TAG McLaren Audio Owners' Forum' started by liamjf, Dec 23, 2004.
  1. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Hello, I have at the moment a marantz Av amp and stereo amp as per signature. My REL sub is connected line level to my AV amp therefore no crossover filtering and also via hi level to my stereo amp speaker outputs so I can prceisely set the x over points, gain etc. for better audiophile sound. Now upgrading tyo the AV32R-bp192 which obviously has different x overs etc for each type of input (cd, dvd etc.) so should I just connect via low level from the TAG (and perhaps upgrade the cable) and set evrything up in the TAGs menu?
    Any help? Thanks, Liam.
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    Livingston, Scotland
    +227
    Liam
    Connect with phono to your AV32R and let it do all the work :thumbsup:
    Try out the different speaker sizes and cut-off points to see which you prefer :smashin:
  3. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Ditto... This way you have less distortion because you spare your front channels, powers and speakers, from playing the lowest frequencies...
    Thats what I do too...
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Same for mine,especially when using the valve amps and Quad ESLs...really does give the amps a lot of extra headroom,by not reproducing all the bass,and spares the ESLs also.
  5. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Just got the sub (in the middle of wholesale revamp) so can you recommend a sub cable (3-5m) that's not too expensive that will do the job. Oh and I'll need a co-ax digi ic for the cd transport as well (LAT, Apogee or stick with qedp75?)
    Liam.
  6. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    What I use after many tests, including way more expensive cables, is:
    Audioquest G-Snake for the subwoofer
    Apogee WideEye digital coax
    Both reasonably priced, and much better than everything else tested...
  7. liamjf
    liamjf
    Dec 20, 2002
    310
    LONDON
    +9
    Thanks for that, what sort of price are we talking and where can I get them from?
    Liam.
  8. Polecatpete
    Polecatpete
    May 12, 2004
    476
    +5
    Ok, just to be different, mines connected using low and high level input..... I found it worked a bit better for me doing this. Think I'm out voted though! :D
  9. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    Apogee 1 meter and Audioquest G-Snake 3 meters, each +- 60 euros...
    This prices from a store in Portugal, should be cheaper in the UK or on the net... :rolleyes:
  10. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,350
    +227
    Liam
    I have a QED cable and works fine. However you should check out the cables section "above" and have a look at the cable service offered by Mark Grant.
    He can supply you with a very high quality lead using the same cable and plugs used by TAG. A 1m length will set you back £25 and £41 for 5m :thumbsup:
  11. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Get the Mark Grant Belden off this forum, they dont get any better :thumbsup:
