AV32R bp-192+Rotel 1075 - Which CD Player ????
Discussion in 'TAG McLaren Audio Owners' Forum' started by Mr THX, Dec 27, 2003.
  1. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Evening Guys
    I'm looking to partner up my processor / amp (see title) with a suitable CD player, was just wondering if the Dac's in the Tag are up to me just purchasing a CD transport and going digital straight into the processor. :confused:
    Thoughts of a Meridian transport or something on the same lines spring's to mind. Proac 1.5 Response speakers complete the circle so all I need now is some ideas for 2 channel play back for me to consider and then demo.....................
  2. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    The Dac's are absolutely amazing. In my opinion you should invest in a good transport.
  3. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    How much are you looking to spend?
    FWIW I use a Densen B400XS (£2.5k) via the bypass and I rekon it sounds better (different) than my DV32R using the 192 DACS.
  4. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    lovegroova
    After just purchasing the processor / amp combo funds allow me to spend between £500/£750. That why I was thinking if I concentrated that money on a decent transport and let the tag do the D/A conversion, thinking I'd get a decent quality sound from it.
    On the Densen you've got (Very nice) at that price :eek: I think I too would trust it to do the D/A conv and route it through bypass on the processor.
    Thanks for the input so far..................anymore ??
  5. marck
    marck
    Jul 10, 2002
    602
    London
    How about one of the Theta transports 2nd hand?
  6. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I'd like to second marck's idea,if you're looking for the best possible CD based input,and suggest either a used Theta(some of which can be found at very decent prices)or the Meridians you already mentioned.
    I use either a Linn CD player as a transport,or the digital out from a UVEM HCPC into a Perpetual Technologies P1A upsampler/interpolator before running that into my AV32R's dacs with very good results....not as good as the P1A/P3A combination,but close enough for convenience.
  7. lovegroova
    lovegroova
    Jul 15, 2002
    2,729
    103
    Herts
    +387
    I'd like to 3rd Marck's idea. For your budget, a good quality transport allied to the AV32's DACs will sound fantastic, much better than a dedicated CDP.
    An alternative would be a 2nd hand/ex demo Tag CD20 with the sync-link which would work very well indeed.
    There is one on offer on the TAG Mclaren website for £800. www.tagmclaren.com - look under 'your 2nd hand market'.
    Also a couple ex-dem at www.sevenoakssoundandvision.com
  8. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Excellent - Cheers for your input guys - I have been looking around as to the availability of a good transport. (S/H one's seam few and far between)
    I have looked at 'Dittons' Meridian 602 on the hardware F/S thread but not sure how much more life I'd get out of a 10yr old transport?? Anyone had experiance of this particular model. The reviews do sounds good but should I be looking for something more up to date ??? Has technology moved us on that much in the CD Transport stakes??
