AV32R: Activate 5.1-bypass via remote?
Discussion in 'TAG McLaren Audio Owners' Forum' started by LJN, Dec 18, 2004.
  1. LJN
    LJN
    May 13, 2004
    64
    Sweden
    Now I have doing the setup for my brand new AV32R BP-192.
    How do I to activate the 5.1-bypass mode via the remotecontrol?
    Thanks for your replay!
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    Livingston, Scotland
    +225
    LJN
    Press " Menu" on the RC then...
    Change Set-up
    Input Options
    5.1 Bypass
    Set for 5.1
    Return
    Key Assignments on Remote
    Chose "Set tuner/aux/cd keys"
    Choose either Aux or CD
    Select audio2
    Save your settings
    Then on your remote double press either the CD or Aux button, depending on where you have "put" your bypass
    :smashin:
  3. LJN
    LJN
    May 13, 2004
    64
    Sweden
    Kenny!
    A big thanks for your fast and perfect answer :thumbsup:
    /Lennart
  4. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,346
    +225
    Lennart
    Happy listening :thumbsup:
