AV32DP shutting down.... "Self Test" ?
Discussion in 'TAG McLaren Audio Owners' Forum' started by RickS, May 7, 2005.
  1. RickS
    RickS
    Nov 14, 2004
    16
    3
    AB,Canada
    Well, last night while watching a movie my AV32DP cycled the power on and off about 5 times. Sometimes it would come back on and other times shut right down. :eek:
    I unplugged the main power and tried it this morning.....same thing. Any suggestions would be greatly appreciated. :lease:
    Rick
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    Rick, it will need to be repaired, it is a problem with the power supply, I had these symptoms along with some error codes, thankfully IAG do know how to fix this. You can expect it to take 3-4 weeks from when they get your unit.
  3. RickS
    RickS
    Nov 14, 2004
    16
    3
    AB,Canada
    liam_b,
    Thanks for the reply! Well, I 'll have to get my AV32R-EX SP out of storage. If you don't mind me asking? How much did the repair set you back? I know the shipping from Canada and back is around $400.00 cdn. :eek:
    Rick
  4. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    +25
    Rick, sorry I no idea of the cost of repair as my DP was 2 weeks old when it failed so was covered by factory warranty. I'm sure IAG will be able to give you a guide figure if you call/email the helpdesk.
  5. lenny
    lenny
    Jul 8, 2004
    435
    Paris
    +6
    Rick,
    is your unit supplied through an UPS? I got the same problems when the voltage on the power supply fluctuates of about +/-10v (on a base line of 230V AC).
    May be your unit does not need to come back to the factory...
    Regards,
    Lenny
  6. RickS
    RickS
    Nov 14, 2004
    16
    3
    AB,Canada
    Lenny,
    I don't use a UPS. But, have constant 118 volts from a dedicated power control center.
    Rick
