AV30R speaker calibration problem
Discussion in 'TAG McLaren Audio Owners' Forum' started by mike.b, Apr 29, 2005.
  1. mike.b
    mike.b
    Apr 29, 2005
    If I run the speaker calibration when analogue bypass is selected as the input on my AV30R, I don't get any pink noise output from the left and right front channels, though the other channels work fine. If I select DVD as the input, the calibration works correctly on all channels. Is this a common/known problem, is it a fault on my amp or is there a way to fix the problem?
    I also occasionally get OVERRANGE (I think that's what it says, it could be OVERFLOW or OVERLOAD) displayed - is there a way of finding out whether this is an input overload, an internal calculation overlflow or an output overload. It may be due to ressignment of the subwoofer signal as I don't have a subwoofer at present.
    Any help appreciated.
    Thanks,
    Mike B.
  2. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    If you hare in Analogue Bypass, you, probably, can´t write any information on the circuito. That why, this mode exist.
    I have get this message one time, I found that was the recording quality.
    In what source you get the error? Probably you have the sensitivity incorrectly configured (mV).
