Av300 + P35
Discussion in 'Arcam Owners' Forum' started by barnythebear, Sep 8, 2004.
  1. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Can I use a P35 with 3 channel board to bi-amp the fronts and centre with my AV300. Is the gain etc OK. :cool:
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Yes everything will work as you would expect and the gains are matched. Don't forget to remove the linking bars on any speakers you bi-amp!
    HTH.
    John Dawson (Arcam)
  3. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Thanks for the responce.
    I'm debating whether to up grade my 170 + black box 3 for a newer CD player or go for the bi-wire of the front speakers. I am already using 6&7 on the AV300 for this. Would an external power amp show a significant improvement or is the newer CD better? We tend to listen to more music at the moment but there is a P35 going cheep!
