raydon
I happy to announce the v2.0 release of AV2HDR.
What's New
Now runs under Microsoft.NET framework v4.0
Uses third party dll now for all FTP functions.
Should resolve problems experienced with earlier versions of AV2HDR when multiple local ethernet adapters were defined on the PC.
In that situation the AV2HDR FTP client could possibly bind to the wrong local adapter.
Much improved transfer speed (up to 40% faster).
FTP logging at two levels, selectable via the FTP settings to assist in diagnosing problems.
Resuming of broken or cancelled FTP transfers. (this function requires vsFTPd server to be running. No resume support in TinyFTP)
FTP file selection via checkboxes, enabling the transfer of an individual file or any possible combination of the three.
Minor improvements to the muxer (which is now in a separate dll also). Video remuxed by AV2HDR will now play in the VLC plug-in.
Option to import epg text from file to pre-populate the Program Information text field of the new HMT file.
This file should reside in the same folder and have the same name as the source video, but with the extension of .epg
Maximum of 254 characters are allowed in this field. if any larger the text will be truncated.
Installation
Unpack the contents or the archive to a folder of your choice.
Right click on each file in turn and select Properties, then Select 'Unblock'.
N.B. The unfortunates who use Symantec/Norton Internet Security may find that some of the files get flagged as WS.Reputation.1 and are subsequently quarantined. In that case you just need to restore them from quarantine.
AV2HDR v2.0 can be downloaded from [Link Removed see below]
enjoy
raydon
v2.0 now superceded. Get v3.0 from HERE.
What's New
Installation
enjoy
raydon
