Av192r Information Required
Discussion in 'AV Receivers & Amplifiers' started by Atagie, Mar 8, 2005.
Tags:
  1. Atagie
    Atagie
    Jan 20, 2005
    70
    11
    The S.W.
    +4
    Please,
    could anyone tell me if there were any revisions ,or pitfalls, in the boards of early AV192R. Was it just software upgrades ?. I am pondering on a exdem unit.​
    Brian.
  2. lenny
    lenny
    Jul 8, 2004
    435
    Paris
    +6
    I've understood that there might be some issues on DTS decoding mods. You can find more details digging into one of the previous thread of this forum.
    regards,
    Lenny
  3. Atagie
    Atagie
    Jan 20, 2005
    70
    11
    The S.W.
    +4
    Thanks Lenny,
    I have just read theads on some disc probs. and 4.31 fixes. The 192R e/dems are likely early 03.​
    Anyone know when 192R first in shops?.​
    Brian
  4. lenny
    lenny
    Jul 8, 2004
    435
    Paris
    +6
    End 2002 but with not all the options available (e.g.: The video scaler and the RS232/ IR interface...). Usually for demo purposes Tag McLaren shipped fully loaded units.
    Typically you should find AV192R with all the Hw options but the video scaler with prices which can range between 4000£ and 7000£. That's before the HifiBiz "mania" started: I mean that now it might be possible to find better deals...
    Regards,
    Lenny
  5. Dr Udo Zucker
    Dr Udo Zucker
    May 14, 2004
    358
    Portugal
    +35
    Hi Brain, there has never been a change to the AV192R's hardware which would make older units less desirable. Of course, the software evolved (but is field upgradable) and some early demo AV192Rs had to come back to the factory to install all interconnect cables (required for future upgrades), making upgrades more difficult for retailers. There has also been an issue with the dual processor card, both in AV32R DP and AV192R, but that was fixed within weeks. Hope this helps...
  6. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    There might be few less desirable AV192R's, namely those with boards originaly upgraded from AV32R.
  7. Atagie
    Atagie
    Jan 20, 2005
    70
    11
    The S.W.
    +4
    If the RS232/IR TX Controller unit is later added to 192R, with front panel flap already fitted, is it just slotted or soldered in. Can this be easy done by a dealer, or is it best carried out at IAG ?
    Brian
  8. Dr Udo Zucker
    Dr Udo Zucker
    May 14, 2004
    358
    Portugal
    +35
    Hi Brian, it is easy to add afterwards. A qualified retailer should be able, however, IAG is always the best solution, in case something goes wrong...
