AV192R Hiccup
Discussion in 'TAG McLaren Audio Owners' Forum' started by Joelc, Aug 11, 2004.
  1. Joelc
    Joelc
    May 16, 2004
    414
    +5
    Has anyone experienced this hiccup... Was watching The Secrete Window on DVD and the audio kept cutting and out. I figured it was a bad rental disk and made due. Last night I put in another DVD...same effect. I now figure that it is either the DVD32R or the AV192R. I decide to power down (i.e. unplug) the AV192R, power up the AV192R abd voila... problem solved.
    Two quick questions:
    1. Does anybody have any idea as to what happened?
    2. Has anybody else experienced this?
    Thanks,
    Joel
  2. DamH
    DamH
    1. No.
    2. Yes. On 4 or 5 occasions.
    I remember thinking it might be my DVD32R though as other audio inputs were unaffected (Although I do have a 'blame my DVD32R' attitude as it is a temperamental :censored: )?
    Either way cured after a suitable period of switching my equipment off... which seeing as it always seems to happen when I invite friends round to watch a movie, is a real pain.
