AV192R/DVD32R automation
Discussion in 'TAG McLaren Audio Owners' Forum' started by awaters, Nov 21, 2004.
  1. awaters
    awaters
    May 19, 2004
    25
    Is anybody else having problems with the AV192R/DVD32R automation?
    I have an AV192R and DVD32R tag communication bus connected. It is obviously working, if you turn on the DVD player the AV comes out of standby, the display intensities are synchronised. However, if I go into change setup, TAG Bus/Automation and select DVD32R it tells me there is no DVD player attached.
    The units have different units numbers (AV is 1, DVD is 2) and the latest software versions.
    Thanks.
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Have you tried another CAT5 cable?
  3. JohnMulcahy
    JohnMulcahy
    Jun 13, 2004
    181
    Aldershot
    +20
    If you have changed the DVD's unit ID to 2 as you suggest above, you need to set it back to 1. Unit IDs are specific to the unit type, they only need to be different when you have more than one unit of the same type on the bus (e.g. two amplifiers).
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    Hi John.
    You mean all this time we could have had a 2 DVD32R's, one for CD and the other for DVD's on the same bus :rotfl: :rotfl: I feel cheated making do with only one all these years :eek:
  5. Neale
    Neale
    May 22, 2004
    83
    Gerrards cross
    Graham are you a time traveller as well you have submitted a thread an hour before you sent!!
  6. Neale
    Neale
    May 22, 2004
    83
    Gerrards cross
    Its Av forums
  7. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    It says 07.19, which was correct.....
  8. awaters
    awaters
    May 19, 2004
    25
    Graham,
    already tried a different cable.
    John,
    thanks - will try changing the DVD unit id this evening.
  9. awaters
    awaters
    May 19, 2004
    25
    Changing the unit id to 1 works - John thanks again :smashin:
