AV192 reset????
Discussion in 'TAG McLaren Audio Owners' Forum' started by pgilford, Oct 29, 2004.
  1. pgilford
    pgilford
    Help! My AV192 won't load it's software - I just get an error message saying switch off for 60 secs. I guess there must be some way of forcing it to reset - does anyone know how?? And will I lose the TMREQ settings??
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Talk to Barry at the IAG helpdesk.
    A full reset will wipe most things so don't do it until you have backed up the settings (this assumes you can!).
  3. pgilford
    pgilford
    OK - they are all out until Monday - so I guess I've got a weekend of silence....! Thanks
  4. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    If the thing is permanently saying switch off for 60 seconds then the DSP card is failing to initially boot at all... it's a long cruel twisted story why this error condition = this message!
    If this has occured since trying to reprogram the unit then chances are the DSP code has been erased from one of the DSP card, without new stuff being reprogrammed in. Go through the reprogramming sequence and hopefully it should be able to force the unit into DSP reprogramming mode.
    If this has appeared all by itself then either the DSP card has failed or the v3.3 power rail has failed. Time to ring up the helpdesk.
    An eeprom reset will not make any difference for this error condition.
