AV Virgin please help
Discussion in 'Plasma TVs Forum' started by Saint James, Sep 21, 2004.
  1. Saint James
    Saint James
    Sep 21, 2004
    2
    I am totally new to all this home cinema, but i am willing to learn fast. i have just bought a panasonic TH42PE30B plasma, which i think is top notch. My plan is to mount it flat on a wall and have no cables showing. i need to connect Sky, DVD player and VHS. here are my questions,
    1. what type of bracket should i buy, do i go for the panasonic as shown in the instruction manual or some other manufacturer.
    2. what do i need to connect all my boxs (SKY,DVD VHS) together with, i am i right in thinking i need an AV reciever.
    3. what cables will i need, i cant use SCART because there is not enough room in the wall cavity to place the cables.
    Any help would be greatly appreciated, as at present i have a very expensive cardboard box in my front room and so far i have been looking for these answers for a week and all i can find is pay an installer to do it for you.
    Many thanks
    Saint James
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Fully wired Skytronic SCART cables 99p each from loadsa supermarkets,
    work perfectly connecting everything. Don't waste more money than u
    have to.
    But if you need to run something thin, buy a Quintro Scart switcher (£60)
    get a JS to VGA box (£120) and run a VGA cable (upto £20 for 10 meter cable) thru the wall as I suspect that will be the thinnest cable option.
  4. red severn
    red severn
    Feb 6, 2004
    163
    +9
    dont do it!
    go to a shop that has good rep and decent selection of cables and audition them yourself a good shop will let you take them home and try a varied selection of materail before making your choice only you will be able to see
    whats best for your equipment you do not have to spend alot of cash but you may well be surprized.
    regards red
  5. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    St. James has a Viera... I don't think VGA cable is an option as the VGA port is front mounted under the flap. :confused:
    S.
