AV using a front projector - 3803 or 2011?
Discussion in 'AV Receivers & Amplifiers' started by mutley, Apr 12, 2003.
  1. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    Was (am) decided to buy the 2011 but then my plans about the display changed (RP to Projector) so don't know if the 3803 would make a huge difference using a projector.
    Any ideas?
    MCACC, THX and the looks (have a 757) are saying 2011 but...
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Probably depends what kit you want to connect to the Projector and what inputs the projector has.
    The 3803 has upconversion (Composite video to Svideo and Svideo to Component video) which may be useful ... or you could add an external scaler instead.
    Vikki
  3. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    sorry... should have posted that info:
    Projector: Sony HS10
    Imputs:
    Pioneer 757 (via component - Prog Scan)
    Sony PS2
    TV (just some footy)
    Gear:
    Rotel RCD 1070
    Sub Rel Q150E
    B&W 603 (602) (601) - don't know yet
    B&W LCR600
    Sonance RS1
    Sony KV28FX60
  4. Dom Rice
    Dom Rice
    Have heard this mentioned a couple of times but would like it explained.
    I have a Denon A11SR amp does this have up conversion? and if so, how does it work?
