AV transmitter required. Sky+ to Z2.
Discussion in 'Projectors, Screens & Video Processors' started by therealijn, Sep 5, 2005.
  1. therealijn
    therealijn
    Oct 14, 2004
    38
    Bannockburn
    My Sky+ box is too far away from my Z2 to reallistically run a cable that will let me watch sky on my projector (probably 15 metres - don't want to drill holes in carpets/floors/walls). I have a scart to s-video converter unit available so I'm looking for a wireless AV transmission system that will do the signal sending from sky+ to converter for me. I did buy a hub and reciever system from B & Q but I could not get a picture on the PJ. It would work sending a picture to a portable tv for some reason. Can anyone recommend a product they have experience of? I realise that s-video might not give me the best picture but I'll be easy to please. Please note there is no scart connection on a Z2.
    Thanks.
  2. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    Is that 15m from box to Z2 or 15m cable run. My run is currently 15m cable run and I use SVideo with no problems. I've got one of those digisender boxes and they're not worth the trouble. They interfere with everything, for some reason their wireless spectrum is huge. I've altered mine from one extreme to the other, at one extreme it completly blocks my WIFI signals, at the other it plays around with the DECT system in the house.
    I ran my under the carpet, we've got underlay so I cut out channel and the cable is now not noticeable. If your worried about spending 70-80 quid on a cable then get it from a place that will accept a return if the product is not suitable ( all internet shops have to offer this).
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    Your Sky+ box already has an s-video out. You do not need a SCART->s-video converter.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The wireless spectrum is huge because video is a wide bandwidth picture. It's unusual to see video transmitters interfering with wi-fi, because the lower bandwidth wi-fi signal is usually stronger (the energy of the signal is concentrated into a much smaller spectrum). If either is interfering with your DECT phones, then you have dodgy DECT phones, because they work on an entirely different frequency (DECT is 1.8GHz, and wi-fi is 2.4GHz) !
    The bottom line is that you will probably find that the quality of a video sender will be insufficient to give you good results on a projector, interference or no interference.
  5. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    I ues to use a digi sender to get the picture to my, the result was terible, the picture was such a mess.
    One question, if Dect and Wifi are so seperate, why does every manual to every bit of wifi kit say that dect phones can interfere???
  6. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    WIFI gets completly blocked out from anywhere but the room with the router in. ( which kinda defeats the purpose). The DECT system we get very poor range when the sender was turned on, I'm still not entirely sure it was down to the sender but its a lot better now I don't use it .. wihch reminds me anyone wanna buy a philips digisender ? :)
  7. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,035
    Harrow, NW London
    +599
    you pay for what you get...
    if it didnt cost a lot then a av transmitter will only want to send a weak signal which wont be strong enough to form a picture fit for a projector....
    normally you're lucky if its good enough for a 14in portable TV...
    Any frequency can affect any other frequency despite being in different bands, i think its something to do with metals (in a house the girders for instance) affect them and can cause them to intefere with each other sometimes.....cant remember the science exactly tho......but this is why you get SACD with supertweeters on your speakers, even tho you cant hear the sound above say 16khz (at 30 years old or so) the sounds you do hear are affected by the sounds higher up...
    if you spend decent money on a powerful transmitter using an extremely unusual frequency range then it should be fine...but tbh it would cost more than its worth in this case...lol
  8. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    TV senders don't run on S-Video, it may have an S-video input but it will only be sending composite. The picture is alright to send 10m to a portable but not to a 80" wide PJ image.
    I've got mine setup with an S-video and phono cables from the Sky+. It is well hidden round the skirting and under the carpet where it crosses the door and then throught the wall to the room with my PJ. No-one as yet has noticed it, and the PQ is good enough for watching the footy and the occassional movie.
  9. Lucas
    Lucas
    Jun 29, 2005
    103
    +3
    Stripe says it all.
    I too have a video sender and it is fine for say a 21inch bedroom TV.
    For anything like a projector it is a waste of time since the degradation in picture quality will become very apparent on say a 90inch screen.
  10. therealijn
    therealijn
    Oct 14, 2004
    38
    Bannockburn
    Thanks all. Great answers. Looks like I'm just gonna have to run a long s-video cable and phono cable as well.
    therealijn.
