Quantcast
AV to Speakers wiring help
pdot
Hi All,
I've just purchased an ONKYO 609 to go with my Mordaunt Short speakers and just need some advice with the wiring.
The Speakers have 2 x +/- terminals on each (high x 2 & Low x 2).
This was fine while wired up to my amp as it was split but now that I have wired up the AV reciever to them it seems I'm only having a choice between either Hi or Low and not both.
Does anyone know the best way to solve this?
Can I just pick one of the speaker inputs and daisy chain some cable to the other?
Thanks in advance,
Paul
PSM1
Just use a bit of speaker cable between the 2 sets of speaker terminals. The speakers should have supplied with a jumper bar connecting the 2 sets of terminals. If this is missing then speaker cable will be fine.
