Av System-budget: 3000 Pounds
Discussion in 'Blu-ray & DVD Players & Recorders' started by drunkenmaster, Feb 17, 2005.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    After spending months on mags shops and this forum I have finally mustered up 3000 pounds to spend on a system. Heres the supposedley type of kit i think I want, opinions please?
    1) Denon 3910
    2) Denon 3805
    3) Monitor Audio Radius 270 system with MJ REF 100 sub
    I have demo'd this and sounds excellent.
    Any other combinations I should demo b4 I take the financial plunge?
    PS advice on cables would be useful if poss. :lease:
  2. AlecF
    AlecF
    Check out some of forum member Mark Grant's DIY cables in the cables sub forum
  3. DOCTOR FURBY
    DOCTOR FURBY
    Jul 18, 2004
    Hi Drunkenmaster
    I'm hoping to buy a similar system to you. Denon 3805 and Monitor Audio Radius speakers (270 fronts, 225 centre and 180 rears) and MJ Ref 200 sub. Are you going for the 90's or 180's for your rears?
    Re DVD, I'm not sure whether to go for Arcam 78 or Denon 3910.
    You asked about cable. I've decided on either Chord Carnival Silver Plus or Chord Rumour.
    Dr F
  4. guido
    guido
    Jan 13, 2005
    364
    +5
    My friend has bought this little lot... similar to you... I would audition the Quads before you take the plunge. Not sure which cables he has gone for though. Think if you are going for 3805 then worth getting matching 3910.
    Denon 3805
    Denon 3910
    Panasonic AE700
    Quad Home Cinema Pack (11L, 12L, 11C, L)
  5. digisocialist
    digisocialist
    Sep 5, 2004
    477
    Yorkshire
    Check my signature. It's very similar... what's your intended display device? I bough I PJ which took me to 3.5K. For 2.5K you get the 2910 / 2805 and a set of MA's or Castles.
    I was very temtped by the 3805/3910 combo. I stepped down and am quite glad I did. There is more than enough delivery in the 2805/2910 combo IMHO. It's worth cjecking them out.. you may not see much difference, if any, and save yourslef a bit of cash to put towards something else as I did. Really, I couldn't justify the extra for the Denon Link and marginally better DAC's.
  6. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    Thanks for the advice.
    Doctor Furby: Most likely the 90's as space is limited wall mounting!!
    Guido: Did look at the quads-going above my budget but mighty tempting
    Digisocialist(cool name): Nice sig My display at the mo is pana 36pd30 but am looking at updating in a couple of years. Sensible thinking.
