AV sync test pattern
Discussion in 'Home Cinema Buying & Building' started by djwoodyuk, Jul 18, 2015.
  1. djwoodyuk
    djwoodyuk
    May 26, 2007
    118
    19
    Middlesbrough, UK
    Hi.
    Does anyone have a download link for a AV Sync test pattern?
    I have a slight lip sync issue that I can't seem to get spot on.
    Regards
    Chris
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,620
    Redditch
    +4,208
    Without knowing what capability you have to play back downloaded files, or the content of the video and audio you have issues (and what you are using for audio playback) without this it's not possible to comment. In the end your displays video processing delay wiil take longer than the audio processing). The BBC had a HD AC3 5.1 synch test broadcast for a long time, if you can get hold of copy it may help but only if this is the source of your issue.
    Try adjusting the delays in say 10m/second increments. Bear in mind if using a AV receiver the adjustment will normally be for the currently used input only.
  3. djwoodyuk
    djwoodyuk
    May 26, 2007
    118
    19
    Middlesbrough, UK
    Thanks for your reply.
    I watch downloaded content on my PS3 (and blu-rays), my other input in the AVR is my Sky HD box.
    Was hoping to fix the issue with the PS3 first and then adjust my Audio delay settings from the sky box.
    Wasn't sure if there was a link to any downloadable files.
  4. JGM
    JGM
    Dec 13, 2002
    1,000
    Alderley Edge
    +233
    Sync-one2 have a selection of test files on their site; Sync-One2 test files
    Whilst they were made for their audio sync tool, you could try them to see if you can adjust the delay by ear/eye.
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,359
    2
    4
    137
    Garstang, Lancs
    +1,632
