AV surround processor to complement Arcam Delta 290 amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by sbyatt, Aug 8, 2001.
Tags:
  1. sbyatt
    sbyatt
    I have an Arcam Delta 290 amp, speakers and source. All I need is a processor to match the Arcam. Can anybody recommend anything?
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Umm, probably an obvious suggestion but you could always look at the Yamaha DSP-E800.
    This will use your existing amp for the main speakers and provide power for the centre & rears.
    Probably find it for about £240 if you look around.
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    If your DVD players got on board decoding you could always try and pick up an Arcam Xeta processor, should be fairly cheap now.
