av stand height
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by osmyth, Jun 3, 2004.
  1. osmyth
    osmyth
    Nov 10, 2002
    281
    16
    York
    Could anyone recommend a 2 or 3 shelf AV stand which is around 50cm high?
    thanks, Owen.
    Update: found one that may be suitable - Optimum AV200 (50cm high exactly). Anyone got one and could recommend?
  2. bobbypunk
    bobbypunk
    if you order optimum stands you can specify the heights of the poles so:
    The feet are 8CM leaving up to 42CM for other poles so if you want 2 shelf a 400mm pole or less will do if you want three and equal spacing 2 lots of 20CM poles would be best (or 10CM and 30CM etc...)
    Just ask your dealer for advice!
