av stand for 36" crt tv
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by newbie265, Nov 14, 2004.
  1. newbie265
    newbie265
    May 21, 2003
    458
    Rochester, Kent
    +4
    I'm looking for an av stand to house my very heavy sony 36" plus a denon 2900.denon 3805 ,sky plus and a monitor audio silver centre speaker and possibly a dvd recorder,.is there such a stand?
  2. DeepS
    DeepS
    Dec 15, 2003
    174
    I have got the same problem, my Sony weighs almost 100kg! I have not seen a decent stand that can handle the weight and accommodate a good sized centre speaker.
    If anyone has seen one, please let me know.
    DeepS
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,549
    Galactica C.I.C.
    +199
  4. bobbypunk
    bobbypunk
    www.optimum2000.com
    the corner av rack (AV2 /3 /4..) should be fine for 100kg (Tested to 500kg!!)
    www.standsunique.com
    The 10mm AV range and the "ultimate" range will also take up to 500Kg, per shelf even load so 100kg is nothing!!
  5. DeepS
    DeepS
    Dec 15, 2003
    174
  6. vizslaraner
    vizslaraner
    Dec 13, 2003
    424
    Hereford
    I've used the Stands Unique HI AV10 and it works fine. Presently I'm using Apollo furniture http://www.apollohifi.co.uk/. Check out "The Kit" for pics.
    David
