AV Setup
Discussion in 'Home Cinema Buying & Building' started by ollie2009uk, Jun 30, 2015.
  1. ollie2009uk
    ollie2009uk
    Feb 6, 2010
    11
    3
    +4
    Hi, Can anyone help me with some advice please?
    I have 2 rooms that I'd like to tidy up. I want to put my sat receivers 1 in my living rooms & 1 in my bedroom) in my loft. I also have an IPTV box that is in my living room which I'd like to out in the loft. Can I buy a HDMI over cat5 box that will take 2 signals in and give 2 out? I have cat 5 wired in my walls and each TV has a cat5 cable chased in behind it.
    Basically I don't want any box's near the TV's I just want the TV on the walls.
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    What you need is HDMI over Cat5/6 matrix , however there are very few if any 3x2 so would need to be a 4x4.
    The proper way is using a HDBaset Matrix as they also carry Infrared and Power over cable,
    Not sure of your budget but £1500+VAT plus for a complete system
    Though we are well aware of lower cost solutions we have found that HDBaset technology is the way to go for reliability and ease
