AV SENDER - V+ box
Discussion in 'Cable TV & Virgin Media TV' started by CMC1985, Feb 7, 2009.
  1. CMC1985
    CMC1985
    Jan 23, 2009
    2
    I have a V+ box and currently have an av sender connected which sends the signal to another tv in my house. I wish also to be able to watch it on one more tv in my house - if I buy another AV sender and connect this as well (so in effect I will have 2 senders connected to my V+ box) will this work ok, please?
  2. DougEdey
    DougEdey
    Jun 11, 2007
    41
    +4
    It depends on the model of AV sender you purchased, it should work fine if it's the same manufacturer and you just set it to the same channel
