AV Recievers?
Discussion in 'AV Receivers & Amplifiers' started by moss6, Jan 2, 2003.
  1. moss6
    moss6
    What do you consider to be the better receiver if choosing between the JVC RX-DP10VBK or the Yamaha RX-V3300 and why. They seem to be very compreable on paper with THD of .02% at 120 and 130 watts respectively at 8ohms. The Yamaha has the 10watt edge in power but the JVC is THX rated. If the receivers are indeed close in performance then the $300.00 savings on the JVC should be a deciding factor in the choice. Your help would be appreciated.
    Randy
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    .........as well as how good the amp sounds to you. I imagine the Yamaha would have a very different sound to the JVC (warm vs bright) so a demo would be good idea too. :)
