AV Reciever for under £200
Discussion in 'AV Receivers & Amplifiers' started by dingbat_stew, Jan 28, 2005.
  1. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    As my last post got no replies i thought i would re-post to see if this one had any luck.
    I need a reciever to power my current set-up:
    Eltax Concept 400 front
    Wharfedale Diamond 8+ centre
    Wharfedale DFS-18 rear
    (I also need some help on findind a sub for <£180)
    I will use it mainly for music but still reasonably often for films so about 70:30 or 60:40 would be good.
    I have been looking at the Pioneer VSX-D514, is it any good and please reply cos i need some help/advice.
    Thanx.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,663
    The 514 isn't bad but you can get 5p change on a Marantz SR4400 from Richer which would probably be better. Subs are harder and will need you to look 2nd hand.
  3. Flimber
    Flimber
    Sep 22, 2002
    13,678
    Yorkshire
    +4,476
    Another vote for the SR-4400 from RS @ £199 (rrp £349). But RS also have the Yamaha RX-V350 for £169 which might also suit.
    Mike.
  4. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    Thanx for your help but i'm going to get the Denon AVR-1705 from empiredirect.com for £169.99.
  5. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    I've just rung empiredirect.com and they can't get any stock on the denon avr-1705!!
    Does anyone know somewhere else to buy it from for £170 or is there any other options.
    I'm afraid this time i've got £170 max to spend because i've just bought my Velodyne CHT-10!!
    Thanx
  6. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    Please can anyone help. Reciever for £170 or less or should i stick out for the Denon Avr-1705?
    Thanx
