AV Reciever for £170 or less?
Discussion in 'AV Receivers & Amplifiers' started by dingbat_stew, Feb 3, 2005.
  1. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    I am looking for something which is possibly on offer??
    I need it to power my current setup:
    Eltax 400 front
    Wharfedale Diamond 8+ centre
    Wharfedale DFS-18 rear
    And i've just bout a Velodyne CHT-10 which is why i only have £170 to spend!
    The Denon Avr-1705 is the one i was looking at but they can't get stock for a while so i'm not sure. Should i hold out for stock?
    Thanx
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Why don't you keep an eye out on the classified section, as loads of decent amps come up for cheap. You could even put a thread up asking for one.
  3. GFS AV
    GFS AV
    Jan 28, 2005
    407
    16
    £170 wont get you much to be honest. If you can seve up just another £40 ish you will get a decent amp. According to another member, you can get the Pioneer 814 for as little as £208 from Empire Direct (in a sale).
    Unless of course you do go second hand.
  4. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
  5. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    The VSX-D814 is £199 but is the VSX-D514 any good?
    How is the VSX-D814 compared to the Denon AVR-1705?
    Is the VSX-D814 good for music?
    Cheers.
  6. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    At the £200 mark, I do not believe any receiver is good for music. You will get some better than others, but you would need to move a segment or two up to find a truly musical receiver, and even then, most still aren't that good.
    The Denon may well be the closest at the £200 mark, unless you can find an end of the line Marantz SR4400 somewhere.
    I think going 2nd hand will bring the biggest benefit, £200 will buy you a decent receiver in the classifieds here.
  7. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Its al relative though, it will certainly be better than most (any) mini/midi system at the same price.
  8. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    Possibly, as long as we don't include the DEnon DM31. But in the seperates world, the closest I've come to a musical receiver at the budget end was a Marantz SR4300.
  9. Ace T
    Ace T
    Sep 17, 2003
    349
    Watford
    +3
    Is it possible to channel an NTL pace digibox through the Pace D814-S....?? If so how as I am seriously thinking on getting this amp. My NTL box has scart and also L and R Audio outs so what would be recommended setup to get picture to my plasma and sound through the amp??
  10. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    +32
  11. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    I've just checked the empiredirect website after going away for 2 days and the Denon AVR-1705 is in stock.
    As it is i was just wondering if there was anything that compares for exactly the same price?
  12. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    +32
    if you are def not going over £180 including delivery, then prob not.
    wasabi
  13. Blackjack II
    Blackjack II
    I'd strongly suggest you have a gander at eBay. Owing to the speed of change in home cinema kit I've seen some bargains come and go recently. I'd suggest you concentrate on quality 5.1 DD and DTS recievers, and ignore later DPL2 and 7.1 receivers, where the money has to be spread across too many amp sections. You could pick up a 2 year old Yammy, Pioneer, or even 'audiophile' brands such as Marantz or Arcam for a snip.
    I spent a packet on a Pioneer VSX1011 THX 7.1 a year back (£700-£1,000) but I still get much better sound in stereo from my old NAD 3020B from 1985, which you can get on eBay for about £30-£60.
  14. dingbat_stew
    dingbat_stew
    Jan 26, 2005
    168
    I couldn.t find what i was looking for on ebay so i rang up empiredirect and they're delivering the Denon AVR-1705 on thursday!
    Hope it goes well with my sub(which is arriving this week(velodyne cht-10))
    and my other speakers and i hope i dont have to upgrade for a while.
    Cheers for your help.
