AV Reciever Component in & out
Discussion in 'AV Receivers & Amplifiers' started by Oliverp, Aug 27, 2006.
  1. Oliverp
    Oliverp
    Jul 9, 2006
    90
    11
    Tresco, Isles of Scilly
    +3
    Sorry if this has been covered before. I'm quite new to AV Recievers and I'm just wondering why I would want to plug a DVD player into the AV Reciever and then into the TV. I.e. why not just plug the DVD player straight into the TV?
    I'm sure this is a silly question, but I don't know the answer!
    Oliver
  2. rob roberts
    rob roberts
    May 7, 2006
    89
    +4
    Depending on the reciever it could upscale the picture for you and if i am not mistaken the video channell carries a certain amount of info for the surround sound tracks. I could be wrong on the second as i am relativeley new to home cinema myself.
  3. huntere
    huntere
    Dec 30, 2004
    1,584
    63
    Perth, Australia
    +237
    Its a conevience thing mainly. Its means the AV reciever becomes the hub of all your entertainment needs. So when you switch on to DVD its swicthes video and audio so no need messing for remote for TV.
    As Rob said depending on amp is could upscale but its unlikely you would see any improvement in PQ. Cerainly not with low end amps.
    No audio is carried by component.
  4. Oliverp
    Oliverp
    Jul 9, 2006
    90
    11
    +3
    Thanks for the replies. I'm looking to start low end at the moment, so I don't think I'll need the video in/out.
    I want to spend about £300 on a speaker package, amp and interconnects. I don't suppose anybody has any recommendations?
    Thanks again
    Oliver
  5. rob roberts
    rob roberts
    May 7, 2006
    89
    +4
    You could do worse than check out the clearance lines on the richer sounds website, you could put together a decent set up for around £300.
    Hope it helps mate.
  6. Oliverp
    Oliverp
    Jul 9, 2006
    90
    11
    +3
    Thanks. I'll check it out.
    Oliver
