AV reciever assistance required
Discussion in 'AV Receivers & Amplifiers' started by dboo, Oct 15, 2004.
  1. dboo
    dboo
    Sep 14, 2004
    28
    I have a panasonic 36 TV which has only scart connections. I was going to buy a Denon AVR 2802 plus 2910 DVD player but realised after much research on this very informative website that the AVR 2805 would not have any scart connections to my TV. Not quite sure how else I could connect it (advice would be gratefully received as I really like the Denon).
    Can anyone recommend any good AV receiver around the £600 price? I intend to use the receiver for music/movie 60:40 and cannot get a plasma TV now as my TV is less than 2 years old.
    Thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Amp does not need to be connected to TV Accept for OSD Scart is just a connection, and it would be possible to cable video into amp and out to TV but needs far more thought about what you are trying to acheive and what you are going to connect.
  3. dboo
    dboo
    Sep 14, 2004
    28
    I wish to be able to enjoy the benefits of surround mode when watching DVds or TV programmes. I guess based on your reply, the real question is what would I lose if I buy the Denon AV 2805 which is not connected to my TV because it does not have any scart connection?
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    You dont use a scart connection from the TV to the amp to get sound. You must have stereo analogue outs on the TV to plug into the amp's tv in and then you can play everything from the tv through the amp. If you dont have stereo outs on the tv (you should have) you will have to get a scart-composite and stereo outs lead.
    Hope this helps :D
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    or a scart break out lead scart to scart with 2 analogue phonos.
