AV reciever advice needed. Too many to choose from :/
3dPj
Hi there. My first post, so Hi :)
I'm after a new reciever. Must have 2 outputs, 1.4 hdmi and be able to output 120hz to my DLP 3d PJ. My current reciever won't go any higher than 60hz.
Any idea guys?
3dPj
Budget is best for the buck really. Anything around 350-500 ish maybe more, Im using a Sony dh800 and have wharfedale moviestar speakers. I was thinking about getting the dh810, but I've read that won't do 120hz.
The 2 outputs is not that important as I could use a splitter, but the 120hz is imperative :)
J2C
I thought the main difference between the DH800 and the 810 was the HDMI 1.4 and being 3D ready?
3dPj
So did I. Won't work with 3d projectors as they need 120hz. Tried everything, and I've read the 810 is the same.
I've gone for a Onkyo 608 in the end. I'll let you know how I get on. :)
3dPj
Update:
608 will show 120hz. Yippee. But the Nvidia 3d vision drivers will not allow stereoscopic playback as it dosent recogise the 608 as a 3d vision device. Going to grab the EDID off the H5630 and amend the recievers inf file.
