AV Receivers for 4 ohm loads
Discussion in 'AV Receivers & Amplifiers' started by chubbyandy, Jan 2, 2005.
  1. chubbyandy
    chubbyandy
    Hi Everyone,
    Which of Denons, Marantz and NAD receivers are able to drive 4 ohm loads better? I have come across a pair of Totem Rainmakers and Arros (both brand new) for 50 % off list. Was thinking of building a 5.1. system around them. A no-no? Deal sounds so delicious.
    Budget up to 600 quid for receiver.
  2. Bails
    Bails
    Oct 15, 2003
    203
    +3
    It's a fair way out of your price range, but as a small starting point I can confirm that the Marantz SR9300 easily drives my 4 ohm Elac 207.2 floorstanders (www.elac.com).
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,089
    notts.
    +64
    Out of the receivers you have mentioned the nad t753 would be able to drive 4ohm speakers very easily i used to own a nad t752 and rate there kit highly,very good in stereo.
    Cheers Gonzo.
