I have a Pioneer VSX531 with a Hisense N6800 and my Xbox One X. I understand the Pioneer is supposed to have 4k passthrough but I've never been able to get it to work, the 4k test on my Xbox always said that it couldn't receive a 4k signal when HDMI through the amp, so I reverted to plugging straight into TV and then optical out to the receiver. I don't think I have it set up properly, if I'm honest.
Anyway, now that the new Xbox is coming out, I've noticed it does not have an optical out anymore. So I'm considering my options going back to HDMI, and trying to set up the amp properly. Has anyone got any advice? From guides I've read, there should be an HDMI port on the back of the receiver that says HDCP 2.2, but none of them do... is there something in the settings I need to change?
My 2nd question is that even if I can get the passthrough to work, I'm looking at upgrading my TV sometime next year to an LG OLED or similar, with HDMI 2.1 inputs. Will my receiver be able to passthrough, I understand the highest refresh rate it can passthrough at is 60hz, which is fine for now, but the LG OLEDs are native 4k @ 120hz. Will I need to upgrade my system? Are there receivers that can handle 4k 120hz passthrough?
I am considering whether changing to a simpler system like a high end sound bar would be a simpler/more preferable set up.
Any thoughts appreciated. Thanks
