AV Receiver with built in phono stage less than £350
Discussion in 'AV Receivers & Amplifiers' started by MrPumpkinHead, Apr 4, 2003.
  1. MrPumpkinHead
    MrPumpkinHead
    Can anyone recommend a good AV receiver with DD, DTS, and PLII, max price £350.
    It must have a phono connection as I do not want to use a phono pre-amp.
    To be used 50/50 music/films.
    Currently considering a Denon 1803
  2. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    Don't know which recievers have a phono stage ... not many probably ... best bet is to buythe reciever you want, then add a QED, Project or similar phono stage for around £40.
    Vikki
  3. narabdela
    narabdela
    Nov 25, 2002
    269
    Glockamorra
    +4
    Why not? It's going to be tucked away out of site and will give you a far better sound than anything on an AV receiver in this price range.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    why not the The Panasonic SA-XR10 Home Cinema Receiver or The SONY STR-DB1080 Dolby Digital Receiver or a turntable with built in phono stage like a Project Debut II Phono Turntable
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I've got a project phono box if your interested, and honestly it sounds better than some built in phono stages, well mainly the rotel one I have upstairs.
  6. MikeK
    MikeK
    As, IMO, no alternative AV receiver at less than £350 is going to sound appreciably better than the Denon you already have, I'd simply add a phono pre-amp to that and spend what you save on DVDs or lager!! :)
  7. Boink!
    Boink!
    Oct 5, 2002
    599
    +35
    Or Both! :D
  8. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    My Denon AVR1803 has a built in phono stage. It's available for around £280 these days.
