Question AV Receiver stereo 2 ch pre out
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by iw3her, Apr 22, 2016.
  1. iw3her
    iw3her
    Apr 22, 2016
    9
    Italy
    I'd like to use (sometimes) an external stereo vintage power amplifier as final amplifier of a kind of AV receiver like Onkyo TX NR-545 o 646 or 609 or similar. (only for stero 2 channels music).
    But reading the manuals i can see that the PRE output (zone 2 or VCD/DVR) sounds only from analogic input.
    Ad so, for example, if I have a CD reader connected by digital coaxial cable to the AV receiver or USB Key used by the receiver or network streaming played by the receiver, I can't use this kind of pre output.
    What a pity, the AV receiver has a very good DA converter!
    .... is there a solution?
    Thanks for suggestions
    Lorenzo
  2. stevos
    stevos
    May 16, 2004
    6,158
    +574
    Find an alternative brand receiver.
    Certainly any AV receiver with 7.1 output would do the job, as this is exactly how i did it (ok into a 7 channel power amp, but same applies) until i replaced my receiver with the pre amp.
  3. Mark.Yudkin
    Mark.Yudkin
    Sep 19, 2007
    9,909
    Zurich, CH
    +1,505
    You need a more "up-market" model - one with pre-outs (zone 2 is not a pre-out and can't be used as if it were). Pre-outs are a feature typically omitted on entry-level models, such as those you listed. For Onkyo, that would be the TX-RZ800 or above.
