m@ver1ck
Any recommendations for A/V Receivers that I can use with a two channel system that would be worth the trouble?
I’ll be using it to power a center channel (if that) - and maybe a sub. The idea is to do pre-out from this AV receiver into the A/V Bypass of the two channel system.
FWIW, the rest of the system is a Naim NDX2, Naim Supernait 3 integrated amp and Totem Signature One speakers - but could upgrade to Totem Forest Signature speakers in the future.
I guess a HDMI switcher would do too - but might as well get good center channel - and want to reuse my two channel system.
High enough quality that it is worth the trouble -
I guess what I'm looking for is a HT receiver that does has a high quality Processor/Dac even with fewer channels supported or a weak amp - since I'm only planning on using it with the center channel.
Alternatively, if there is a fancy sound bar that takes multiple HDMI inputs - I'd be fine with that as one - would love it if I could still somehow use the 2 channel system that I have at the same time. FWIW - the $400 sonos sound bar sounds fine too - it's just that I'd also like to use the 10K 2 channel system at the same time if possible.
- as compared to say Optical out from TV (which has lip-sync issues that I can’t get around).
- high enough quality that it is overall better than airplay into the NDX2 from an apple tv (which only uses airplay as temporary speaker) - although I get it that the dac in the 2 channel system might be hard to beat (it's an overpriced 5K Dac)
- and doesn’t cause strange ground loop issues that are hard to debug.
