AV receiver newbie, set-up advice!
Discussion in 'AV Receivers & Amplifiers' started by Gary561, Feb 9, 2014.
  1. Gary561
    Gary561
    Jul 30, 2013
    I'm a bit of a newbie when it comes to amps and set-ups but I have just bought a pioneer vsx-922 and using it to run a tannoy 5.1 sfx speaker set, my question is it doesn't seem very loud and I have to turn the amp volume up to about -19d.b how do I set-up correctly so it's louder at a lower volume?
    I did run the auto mcacc.
    Thanks in advance
    Gary
  2. MIFF INFIDELIUS
    MIFF INFIDELIUS
    Apr 9, 2013
    194
    Usually above sea level
    +24
    Try changing the MCACC to one of its 6 presets. I've had mine at 5 ( press the mcacc button repeatedly on your remote till memory, in my case 5, comes up ) as any other preset was too quiet. Have a play with DRC and other settings, like phase. There are quite few settings that can be adjusted so just have a play around to see what each does but first of all I'd re-check if all your wires are properly connected and that the right terminals are used.
    EDIT - I've also re run the mcacc couple times till I was happy as each time the results were slightly different
  3. Rodders53
    Rodders53
    Dec 8, 2007
    5,227
    Bedford
    +950
    The amp is probably designed to provide 'reference level' volume when set to 0 dB... So running at -19dB for a sensible listening volume may well be correct.
    I think there may be a sticky that explains this, at the top of the sub-forum.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    Can you get the amp to the volume you want/need? If so then does not matter what the display says then it is working fine. You only need to worry if you can not get the volume you require and/or you hear a lot of distortion.
