AV Receiver: Need more optical inputs!
Discussion in 'AV Receivers & Amplifiers' started by Willy, Mar 21, 2003.
  1. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Hi, my AV Receiver only has one optical input, which is currently being used by my Xbox.
    I want to add a DVD player, and that's going to need an optical connection too. Is there such a thing as an optical switch box or hub or something? Is that the best route or is there another way to do this?
    Cheers...
  2. Ravi 123
    Ravi 123
    You could use the coxial output if you have one avialable !!!
  3. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    It has one. Do they do the same thing then?
    Sorry if that's a stupid question! :blush:
  4. Ravi 123
    Ravi 123
    It sure does :smashin:
  5. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Excellent. Thanks very much!
  6. Sunday Ironfoot
    Sunday Ironfoot
    Some people even say the Co-axial cables sound better than the Optical one's, but the Jury's out on that one.
  7. Jonathan West
    Jonathan West
    Try www.lektropacks.co.uk ...
    and also, the coax and optical routes are the same,but if your DVD does not have a coax output you need optical or a converter ... (for which also see web site quoted) ...
  8. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Thanks all,
    The dvd player I want is the Toshiba SD520E, which has a coaxial output, so looks like I'm fine there.
    Cheers, much appreciated. :)
