Quantcast
AV receiver for rx6's and monolith
d4ns
Im after a few suggestions as to what would complement my current set up well. Im currently using a cambridge audio 540R, but i think the speakers deserve better.
Monitor Audio Rx6 fronts
Monitor Audio RX centre
Monitor Audio RX1 rears
BK Monolith DF
Van Damme 2.5mm cabling
From the searching ive come across the Yamaha RX-V3067 but seems quite old now and very hard to find. Wouldnt mind buying used, would just like a few suggestions around the £700 mark if there is anything that will work well.
Thanks as always.
Dan
pistolpete1
I suggest.....
Denon AVR3312 (£645)
Marantz SR 6006 (£699)
Yamaha RXA810 (£699)
Or new Onkyo 616 (£600)
If you can find a Marantz SR7005 or Onkyo 709/809 under £700, I'd defo demo them......
Goldenbone
I have the Yamaha 2067, with RX8's, RXFX, and RXC - along with a monolith+. The only downside is that it YPAO, the Yamaha auto setup, lacks sub eq functionality. The speakers sound magic though
d4ns
Gone for a Marantz SR7005 as found one for £699. Can't wait to get it and have a play. :D
philbot
where where where?
Similar threads
