dante01
You'd get everything associated with HDMI version 2.1 from the PS5 if connected directly to an HDMI input on amn HDMI version 2.1 compliant TV. THe AV receiver doesn't need to be HDMI version 2./1 compliaant for such a setup because the source vide isn't being passed through said AV receiver. THe issue you'd have with older AV receivers would relate to how you'd then access the audio being passed through the TV and out to the AV receiver. Games consoles use multichannel PCM trelative to game audio and this cannot be conveyed via either S/PDIF optical or via standard ARC. You'd therefore want both the TV and the AV receiver to be eARC compliant so that you'd be able to pass the multichannel PCM audio sourced via the PS5 through the TV and out to the eARC enabled AV receiver.
Some more recent AV receivers that pre date HDMI version 2.1 include eARC.
