av receiver and rotel ra-02
Discussion in 'AV Receivers & Amplifiers' started by b!lly, Jun 30, 2005.
  1. b!lly
    b!lly
    ithere pretty new to all this so bare with me...
    i have a sony av receiver and i have just bought a rotel ra-02 amp,i am going to be purchasing a nad c521 BEE cdp,and was unsure in which way to set them up.
    i was thinking of just using the av receiver for dvd etc and connecting the others to the rotel,but how do i do this with only two speakers.
    is there any other way to configure all this together....
    p.s....the av receiver has the built in tuner that i was hopeing to use(instead of buying a new one.
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    You connect the pre-outs of the AV receiver to a line input on the Rotel. The front stereo speakers are connected to the Rotel and the remaining speakers connected to the Sony. A search for integrating a stereo amp will produce alot of info.
  3. Dfour
    Dfour
    Jan 19, 2004
    3,992
    71
    Bracknell
    +85
    The other less pain in the a**e way is to but a quality speaker switch box. I think QED do one.
  4. b!lly
    b!lly
    excellent thanks for the info,will give it a try as mentioned in the first post then maybe try the speaker switch method,
    thanks again
