AV Processor !
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Oliv83, Mar 27, 2002.
  1. Oliv83
    Oliv83
    Hello All !
    I have a YAMAHA A590 (Dolby prologic) and want now to have Dolby Digital and DTS.
    I heard good things about YAM E800 but is there other possibilities to increase my system to 5.1 (YAM or not ... what could be the cheapest)
    Oliv from France ;o)
  2. Markster
    Markster
    I would be tempted to just buy a new amp. and sell your old one.
    The yam620 for example with dts is only £269 whereas you would be paying not much less for the E800.
    worth considering.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Oliv, do you have already a stereo amp in use? If not, the E800 isn't suitable and you need a fully-fledged AV amp/receiver like the one suggested. But there are many other models available, so please compare first.
  4. Oliv83
    Oliv83
    :blush: I already have an AV from Yamaha but only Prologic and I now want to evoluate toward 5.1 (DD & DTS)
    What's the best way without changing everything ? I try to conserve my old (but really efficient AV) and add an external decoder
    Do you know solution like DSP E800 (from Yamaha) but cheaper
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I think you are better of replacing the whole thing. Alternatively to the E800 you can use any AV amp/receiver with pre-outs (line level connection) for the front channel.
  6. DRC
    DRC
    Does your current prologic amp have a six channel input , if so you have the option of using a DVD player with 6 channel out.
    This is what I have on my current set up, only dd due to may player is 3/4 years old. (DTS was not around much then)
    I will stick with this set up in the house but I am currently mid way setting up a new home cinema. (pana 100ae,3802 (if they ever get them in gold), MA silver speakers and ofcouse a new player (TBD)).:cool:
