AV Processor Set-up
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by gwc, Nov 21, 2003.
  1. gwc
    gwc
    Oct 21, 2003
    497
    Wokingham, Berkshire
    +7
    I presume the best way to set-up a processor is with an SPL meter, any recommendations?
    Are the internal tone generators good enough or do you need some sort of calibration disk?
    gwc
  2. Jase
    Jase
    Mar 16, 2001
    9,466
    South Coast
    +891
    Ideally a setup disc such as AVIA or Digital Video Essentials will give you the most accurate calibration as they bring the dvd player into the playback chain. Internal test tones can be wrong unless it's a THX certified processor/amp which "should" be spot on. :)
  3. gwc
    gwc
    Oct 21, 2003
    497
    +7
    Thanks for the advice.
    I have just bought a second hand lexicon MC-1 and I am waiting for it to arrive.
    So I assume the test tones from this should be adequate.
    gwc
  4. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    The test tones are just help to start, in the end I adjusted the center speaker a bit down and the surrounds a bit up, the SQL meter is useless for bass, either use ETF, or do it by ear... :rolleyes:
  5. rags
    rags
    Apr 13, 2003
    4,087
    London
    +303
    Actually thats a good point as when I swapped my Pioneer 717 player for a 565 sound levels did drop sightly.
