So if i upgrade to IOS 6 which i thought was released tomorrow i will lose AVplayerhd?
I upgraded to iOS6 today and AVPlayerHD is still on my iPad.
Yes. Provided you use the same iTunes account.Professor Chaos said:I bought this app ages ago, and if I do a clean install of 6.1 on my ipad2 will I still be able to download this again?
Kyuss72 said:Yes. Provided you use the same iTunes account.
I thought it was back on the App Store now?Will it be in the Purchased apps section even though its not on the App Store any more?
wormvortex said:Will this stream files from a nas?
moraybank said:AvplayerHD has went the same route as Buzz and removed DTS support in the latest update.
I installed this on my GF's iPad mini, knowing that I've used it for the last couple of years with no problems.
I loaded 12 110MB sized MKV's, put them all into a folder, happy days.
Since then, her Mini has crashed mid episode twice.
Now is this down to the app or the Mini? I've had 350mb avi's play on my iPad 2 with no problems whatsoever, so a bit unsure as to what the problem might be....
Any suggestions?
