AV Out problem Hitachi 42PD23000/Sky+/Panasonic DMRE50
Discussion in 'Plasma TVs' started by plusman, Dec 8, 2003.
  1. plusman
    plusman
    Dec 4, 2003
    28
    Which are the best set of AV connections to link these 3 devices together using SCART leads?
    I have just bought a Panasonic DMRE50 DVD Recorder to download some of my saved Sky+ programmes to. I have tried both the top (VCR) and bottom (TV) SCART outputs from the Sky+ box (with picture output set to RGB), connected one of these to the AV input on the Panasonic DMR E50, and connected the AV output to either the AV1 or AV2 inputs on the Hitachi 42PD3000 multimedia box. If I set the picture input and output on the Panasonic E50 to "RGB" I get sound but no picture (even though my Sky+ box is set to "RGB"). If I set the E50 to "Video" I get a picture, but it isn't great quality.
    What am I doing wrong? Can anybody suggest the best set up?
    Many Thanks
  2. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,477
    Chesterfield town of the crooked (Spire)
    +72
    Remember AV1 on the tunerbox is s-video/composite only, AV2 & AV3 are RGB inputs.
    Your dvd recorder should be connected to AV2 and your sky+ box to AV3 via the tv scart outputs on the back of each unit. Your Sky+ video scart output should then be connected to the dvd recorders scart input. Everything set to RGB should then work, maybe the cable connecting the two unit's isn't fully RGB wired ???
  3. kharris777
    kharris777
    Thats exactly what happened to me when I couldn't get it working. I forgot that the cable wan't fully wired!!!
