AV Novice needs help!!
Discussion in 'General TV Discussions Forum' started by m5anj, Dec 30, 2003.
  1. m5anj
    m5anj
    A question to all the AV gurus out there,
    I have the following bits of hardware that need plumbing together:
    Toshiba 36ZP18P
    Panasonic DMR-HS2
    Panasonic VCR
    Grundig Skybox
    I am currently in the process of procuring the appropriate connectivity leads/cables and this is where it all goes a bit Pete Tong!
    What are the best leads to use, how many do I need and what should be connected to what???? Bearing in mind that I am not to precious about being able to record to VHS. It is of primary importantance that I get the best possible picture/sound from my DVD source, closely followed by the Sky source. It is imperative that I can record Sky onto the DVD recorder.
    I would also appreciate some direction with regard to the branding of such leads/cables, obviously price will dictate the final choice, but I can run to about £30-40 per scart cable for instance.
    I know that I am not worthy of your time on such mundane matters, but please take pity on this novice who has been infected by the virus known as AV.
    Cheers:smashin:
