AV/IR wireless sender recommendation.
Discussion in 'Home Cinema Control & Remote Controls' started by Darren Blake, Sep 15, 2003.
  1. Darren Blake
    Darren Blake
    Apr 28, 2003
    621
    Norwich, UK.
    +15
    I am thinking of having a flat screen TV in my bedroom (just a small 15" LCD or something). Ideally I would like to "mirror" my lounge home cinema to this screen wirelessly by taking a video and stereo feed out of my Denon AVR into a transmitter, and relaying the signal upstairs. I would also like the unit to bounce my OFA Mosaic remote signals back down to the HC setup so I could control everything just as if I was sat downstairs.
    I am aware that there are several products out there that could do this. My main issues are:
    1) Compatability with my OFA remote.
    2) Range on the IR transmitter / reviever. This would need to be about 12" at either end: i.e. NOT an "IR eye" that hangs in front of the Sky box / DVD etc.
    Recommendations, anyone?
    TIA.
  2. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    I'm using the Philips VL1200 (composite only) which works very well on my 14" bedroom portable... I have tried to feed the receiver output into my Xantech distribution amp with no joy... Not enough current I think...
  3. Darren Blake
    Darren Blake
    Apr 28, 2003
    621
    Norwich, UK.
    +15
    Cheers for the reply.
    Can you tell me if any of these units have a "broadcasting" type of IR eye on the transmitting end (i.e. the end nearest the home cinema equipment), or are the all of the type where the IR eye is a small, short range thing which has to be aimed straight at your equipment from, say, 12" away?
    Reason I ask is that I can place my OFA remote next to my HC equipment facing away from it and still operate all the components without a hitch by bouncing the beam off the opposite wall - a round trip of about 20 feet for the IR light! If the IR eye on the transmitter was similarly capable, it would make arranging it on my HC cabinet a peice of cake.
  4. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    None to my knowledge... I'll post here if I get any further...
