AV Input Settings.
Discussion in 'TVs' started by Colonel, Jan 24, 2005.
  1. Colonel
    Colonel
    Hello AV Experts
    I installed a Stero Audio Video cable on my Sega Genesus to provide
    crisper images and stero sound. I connected it to the three(3) ports
    that are color identified by yellow, red and white. The other end of the
    cable, I connected in the rear of the Sega unit. The last instruction on the literature that is packaged with the cable is where I need help. Here is the statement: "Select the audio/video input setting on your stero TV". Is this accomplished with the remote control? Keep in mind that the Sega unit was in
    use with an RF adapter designed for the Sega. I removed the RF adapter so
    I could plug in the new AV cable to the rear of the Sega.
    Thank you for your consideration.
    ltclwh@cox.net
  2. Ch3tan
    Ch3tan
    Oct 6, 2004
    289
    Croydon
    +23
    Press the AV button, a box with an arrow going into it usually. If you have more than one AV input on your TV you may need to cycle through them before you find the one your console is plugged into.
  3. Colonel
    Colonel
    Not able to put your answer to a test. There is no AV button on the TV set or the
    remote controller. The TV has a menu button, however none of the items seem applicable. The remote has a setting button and none of the items that come up seem
    to relate to what I'm trying to accomplish either. Hope you are able to give me some more information.
    Thank you.
    ltclwh@cox.net
  4. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    If it is an older set might have to tune in a unused channel and use that.
