M
mark67
First time here, so hi all.
I have a tired Yamaha Processor which has only got PL.
So, I want a Processor that has PL2 etc. But I cannot findone for £350.
So I thought about using an AV Amp as a Processor instead.
Can you suggest some for about £350 or there abouts?
I would be using it with a Tagmclaren DPA 32 Pre and a MF A300cr Power.
Could you suggest any Av amps.
Also, do you wire one up the same way as you would a Processor?
Cheers.
Cheers.
