AV Control centre
Discussion in 'Cables & Switches' started by Andywilliams, Dec 28, 2003.
  1. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi folks
    Found this unit on play.com you can have 4 scarts-rgb 4 phono 4s-video and 4 optical in to 1 it comes with remote control for easy switching between sources latest technology to prevent loss of signal, the casing is also metal so is quite well built all for 39.99 which seems a steal for what you get.
    Cheers Gonzo. :)
  2. Kramer
    Kramer
    Awaiting stock.
    Here.
  3. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    48
    Leicester
    +56
    Now showing back in stock - anyone tried one out yet?
  4. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    Does it allow for auto widescreen switching?
    Does it auto detect a signal when you turn a device on and return to the previous device when you switch it off?
    If so and pic and sound quality is transparent then this looks better than ny Quintro+ !
  5. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    my order arrived today. Not opened it yet but the parcel is HUUUGGGEE!! Way bigger than what I was expecting. The box is about the size of a full size hifi seperates component but slimmer. Weighs a bit too.
    will post first impressions later on.
  6. gedo
    gedo
    Let us know how you get on with this as it looks a promising piece of kit.
  7. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    got the thing installed. It's as wide as my Tosh SD900E player, about 3inches shorter in depth and about 2.5inches high. It wouldn't look out of place on a systems rack.
    very solidly built with a full matt black metal case and chassis. Has 2 silver buttons either side of the front for power and input select. Also has Nice funky little remote control to select the inputs. Has red, green and blue LEDs to show power and input select.
    No picture or sound loss as far as I can determine. Comes with scart, stereo phono and SVhs leads. Every input has an optical input too.
    Bargain for £40 and much better looking than the quintro.
    Have a pic if someone is willing to host for me :)
  8. BigAde
    BigAde
    Jul 22, 2002
    1,025
    East Sussex
    +30
    Sounds good... my Quintro+ might be going back then!
    I had noticed picture degradation while using the Quintro+ if more than one source is powererd on at a time. So if this one is better built, cheaper and better quality it sounds like you can't lose. :clap:
    Any downsides?
  9. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    only minor glitch was when Tivo was connected to one of the sockets, it kept switching the TV screenmode from wide to smart and back again every couple of secs. Used a different socket for the TIVO and the DVD for that one and everything is fine.
  10. BigAde
    BigAde
    Jul 22, 2002
    1,025
    East Sussex
    +30
    Also, I suppose you won't be able to 'lock' one of the inputs for VHS recording purposes (unlike the Quintro+). Mind you, the only source I'm likely to want to record from is the freeview box, so I can simply connect that directly to the second SCART on the video....
    Quintro+ is definitely going back!
  11. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    not sure how you mean by lock an input. the box doesn't autoswitch between sources, you have to manually select the input source.
  12. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    Does it auto detect a source when you turn a device on and revert back to previous when you turn a device off like the Quintro+ ?
  13. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    Thanks, i'll stick with my Quintro. Once you get used to autoswitching you can't do without it!
  14. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    I have a pronto remote. I've set it up so that the box will switch whenever I select the appropriate device on the remote.
  15. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Does it support rgb both in & out on any of the scarts?
  16. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    full RGB in and out on all scarts. Does do signal conversion though ie if you want a composite signal output, you have to feed in a composite input, it won't take it from the scart socket
  17. BigAde
    BigAde
    Jul 22, 2002
    1,025
    East Sussex
    +30
    Agreed. Had just assumed it did autoswitching! Seems a rather poor oversight from an otherwise excellent spec. I guess Quintro+ is staying until I find a worthy replacement.
  18. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    Are you sure as this would be very hard to implement ?
    I`m using a Quintro+ which has RGB out on the TV scart and also RGB out on the first Video scart which is really useful to be able to record to my DMRE100 in RGB.
  19. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    sorry I meant full RGB inputs from all input sockets and RGB ouput from the AV out
  20. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Thats the problem tho, you can record onto disc in rgb but you cant play it back in rgb. One of the reasons i returned my quintro+, that and it didnt work properly:(
  21. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    :confused: Why couldn`t you play back in RGB ?
  22. Jason
    Jason
    Dec 6, 2002
    755
    28
    Luton, Bedfordshire
    +30
    Hi, if I plug in a source via scart can I output the sound via the L and R phono outputs on the Control Centre?
    Cheers, Jason
  23. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    Yes :)
  24. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    no you can't. it doesn't do signal conversions. it only outputs what you input ie scart input to scart ouput, stereo phono input to stereo phono output, etc. You can have for example scart input to s-video output.
  25. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    RGB in and out is easy, the only addition to be made from an RGB IN only socket, is to add a composite video OUT. RGB uses the same three R, G & B pins in either direction and just needs the correct composite sync.
  26. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    :confused: eh
    He`s talking about sound not picture
  27. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    It might have been a fault as quintro unit wasnt working properly anyway, but I had my dvd recorder connected to it on one of the rgb scarts (an out one i think) and it recorded in rgb fine but when you played it it came out composite. Thinking about it again now, did I need to use two scarts for it, one in one out?
  28. CARLOS
    CARLOS
    Feb 11, 2001
    6,432
    WEST MIDLANDS
    +1,411
    Yeah thats the way mines wired with two scarts.
  29. mickl
    mickl
    Sep 10, 2002
    1,314
    48
    +28
    I know what he meant. My explanation wasn't very clear. The manual specifically states that any output signal has to come from a corresponding input signal.
    There, clear as mud :D
  30. [Slip]
    [Slip]
    Jan 28, 2004
    190
    +4
    I have this unit (Joytech) and really like it, was surprised about the size of it but looks fine in the setup I have.
    The only thing is that the remote doesnt work! Might just be a dud battery, but I have a Kameleon 6.
    I don't suppose anyone has a working remote and a Kameloen and could get me the proper code for this device? Or would know how I can get it?
    Defeats the point of a remote control cos I have to get up to change source! :)
