AV Control Centre 245C Black -Component,S-Video & Optical Audio
Discussion in 'LCD & LED LCD TVs Forum' started by thedude2011, Apr 24, 2007.
Tags:
  1. thedude2011
    thedude2011
    Apr 8, 2007
    280
    manchester
    +9
    I am Thinking of buying this AV Control Centre 245C Black -Component,S-Video & Optical Audio from http://www.futureshop.co.uk/av-control-centre-245c-black-componentsvideo-optical-audio-p-796.html I will be conecting my Xbox360 my Ps3 And my Laptop And A Panasonic DVD/AMP Soround Sound To my Phillips 42" LCD Tv ..... I am Going to have to buy Component Leads for the laptop and the DVD player ..... Will it be in my benerfit To spend £40-60 pounds on Leads or just go to a local Maplin and pay 5-10 pounds ? will i see a diffrence ?? thanks anthony..
  2. thedude2011
    thedude2011
    Apr 8, 2007
    280
    manchester
    +9
    thanks for answering my question guys gr8 help to me :) .............
  3. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Don't expect anyone to help you now. Sarcasm doesn't get you far in life.
  4. thedude2011
    thedude2011
    Apr 8, 2007
    280
    manchester
    +9
    Well the post has been up for 2 days and no 1 as even atempted to help me ..... how hard is it to say yes buy expensive leads they are much better or .....buy cheaper ones they dont make much diffrence ? i dont know much about TV's and Stuff like that ....so i came here for help because it was recomeneded to me but why when no 1 can take 10 minits to answer my question but there is over 200 members online ????
  5. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    As has been said above,sarcasm wont win you any friends.
    It's also worth saying that if you'd placed this in the cables and interconnects section you may have had more answers....
    Anyway...given the items you're wanting to connect,and the relative prices,it's probably not worth laying out a huge amount of cash on the leads,and buying relatively inexpensive,but decent leads from a manufacturer such as QED or similar,or if choosing from Maplins,look carefully at the lower priced items to be sure of getting something robust enough.
    Many very cheap leads prove to be a bit of a waste in the end due to cheap build etc.
