AV connectors for XBox - svideo / optical
Discussion in 'Xbox Forums' started by bobwylie, Dec 27, 2004.
  1. bobwylie
    bobwylie
    Dec 27, 2004
    10
    Kirkcaldy
    Does anyone know where I can get a decent cable for my Xbox. What I am looking for is a cable that has an s-video plug, and a digital optical cable. The other twist is that I need too sent the cable on two different routes, so ideally, I need a run-off connector at the x-box end for the digital optical. Help... :lease:
  2. NeoAnnihilator
    NeoAnnihilator
    you got me. I have a question for you. How do I share my pc connection to my xbox via ethernet when my pc is recieving a connection wirelessly from a network (which shares a direct connection)? I've been working on this for quite some time.
  3. bobwylie
    bobwylie
    Dec 27, 2004
    10
    Kirkcaldy
    This is something that I will be looking at too, you can get a wireless ethernet bridge to add a remote ethernet point next to your xbox. Check out WGA11B - Wireless-B Gaming Adapter, on the linksys web site.
  4. NeoAnnihilator
    NeoAnnihilator
    That sounds good, it's not that much either. I've actually seen something else that converts a controller plug to usb; an xbox controller plug to usb cable. I wonder if you could use a wireless adapter or a bluetooth to do the same.
  5. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    Neo. So your PC is wirelessly connected to a DSL wireless router for internet access?
    And you wish your Xbox would connect through the PC to the Internet?
    Is there a reason why you want to connect your xbox to the PC, or do you jsut want it to connect to Live?
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    They sell one in Woolworths or Big W stores.
    Comes with composite, RGB scart, s-video, l/r audio plus optical out for £14.99.
    Cap :)
