AV connections on Pannasonic e85
Discussion in 'Blu-ray & DVD Players & Recorders' started by yetiuk, Aug 3, 2004.
  1. yetiuk
    yetiuk
    Jan 8, 2003
    26
    London
    On the panasonic website it lists 4 AV connections but there is no diagram showing the layout.
    I would like to be able to connect Sky+ (RGB), LaserDisc (S-Video + LR Stereo) and VCR (composite) all into the E85, and output the signal to TV(RGB).
    I'm guessig
    AV1 -> TV
    SKY+ -> AV2
    LD -> AV3 (S-Video + LR stereo)
    Video -> AV4 (front composite) which I can connect when dubbing VHS
    With this setup I will be able to record from SKY+, LD or VHS, and output straight to the TV. Also RGB passthrough will work for SKY+
    Can anybody confirm this is correct. Also are there any other HDD machines with 4 AV connections.
    Yeti
